The following tables, groups, and variables are supported in this MIB.
| Table/Group | Supported Variables | Comments |
| IsisSysTable | isisSysInstance | |
| isisSysVersion | ||
| isisSysType | ||
| isisSysID | ||
| isisSysMaxPathSplits | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysMaxLSPGenInt | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysMaxAreaAddresses | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysPollESHelloRate | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysWaitTime | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysAdminState | ||
| isisSysLogAdjacencyChanges | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysNextCircIndex | ||
| isisSysL2toL1Leaking | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysMaxAge | ||
| isisSysReceiveLSPBufferSize | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysExistState | Only state destroy (6) is supported. | |
| isisSysLevelTable | isisSysLevelIndex | |
| isisSysLevelOrigLSPBuffSize | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSysLevelMinLSPGenInt | Supported isisSysLevelMinLSPGenInt range is 1 - 120 (MIB is 1 - 65535). | |
| isisSysLevelOverloadState | ||
| isisSysLevelSetOverload | ||
| isisSysLevelSetOverloadUntil | ||
| isisSysLevelMetricStyle | ||
| isisSysLevelSPFConsiders | ||
| isisManAreaAddrTable | isisManAreaAddr | |
| isisManAreaAddrExistState | ||
| isisAreaAddrTable | isisAreaAddr | isisAreaAddrTable only displays the contents of the isisManAreaAddrTable. |
| isisSysProtSuppTable | isisSysProtSuppProtocol | |
| isisSysProtSuppExistState | Supported as read-only. | |
| isisSummAddrTable | isisSummAddressType | |
| isisSummAddress | ||
| isisSummAddrPrefixLen | ||
| isisSummAddrExistState | ||
| isisSummAddrMetric | Supported as read-only. | |
| isisSummAddrFullMetric | Supported as read-only. | |
| isisCircTable | isisCircIndex | |
| isisCircIfIndex | Supported as read-only. | |
| isisCircIfSubIndex | Supported as read-only. | |
| isisCircAdminState | Setting isisCircAdminState to off (2) deletes the entry. | |
| isisCircExistState | Only state destroy (6) is supported. | |
| isisCircType | Only broadcast (1) and ptToPt (2) are supported for isisCircType. | |
| isisCircExtDomain | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisCircLevel | ||
| isisCircPassiveCircuit | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisCircMeshGroupEnabled | ||
| isisCircMeshGroup | ||
| isisCircSmallHellos | ||
| isisCircLastUpTime | ||
| isisCirc3WayEnabled | Supported as read-only. | |
| isisCircLevelTable | isisCircLevelIndex | |
| isisCircLevelMetric | Supported isisCircLevelMetric range is 1 - 63 (MIB is 0 - 63). | |
| isisCircLevelWideMetric | Supported isisCircLevelMetricWide range is 1 - 16777214 (MIB is 0 - 16777214). | |
| isisCircLevelISPriority | ||
| isisCircLevelIDOctet | Supported as read-only. | |
| isisCircLevelID | ||
| isisCircLevelDesIS | ||
| isisCircLevelHelloMultiplier | Default isisCircLevelHelloMultiplier is 3 (MIB is 10). | |
| isisCircLevelHelloTimer | Default isisCircLevelHelloTimer is 10000 ms (MIB is 3000 ms). Supported range is 1000 - 600000 ms (MIB is 10 - 600000 ms). Fractions of a second are rounded to the nearest whole second. | |
| isisCircLevelDRHelloTimer | Supported as read-only. isisCircLevelDRHelloTimer object is computed as 1/3 of isisCircLevelHelloTimer. | |
| isisCircLevelLSPThrottle | Default isisCircLevelLSPThrottle is 33 ms (MIB is 30 ms). | |
| isisCircLevelMinLSPRetransInt | ||
| isisCircLevelCSNPInterval | ||
| isisCircLevelPartSNPInterval | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisSystemCounterTable | isisSysStatLevel | |
| isisSysStatCorrLSPs | ||
| isisSysStatAuthTypeFails | ||
| isisSysStatAuthFails | ||
| isisSysStatLSPDbaseOloads | ||
| isisSysStatManAddrDropFromAreas | ||
| isisSysStatAttmptToExMaxSeqNums | ||
| isisSysStatSeqNumSkips | ||
| isisSysStatOwnLSPPurges | ||
| isisSysStatIDFieldLenMismatches | ||
| isisSysStatMaxAreaAddrMismatches | ||
| isisSysStatPartChanges | ||
| isisSysSPFRuns | ||
| isisCircuitCounterTable | isisCircuitType | |
| isisCircAdjChanges | ||
| isisCircNumAdj | ||
| isisCircInitFails | ||
| isisCircRejAdjs | ||
| isisCircIDFieldLenMismatches | ||
| isisCircMaxAreaAddrMismatches | ||
| isisCircAuthTypeFails | ||
| isisCircAuthFails | ||
| isisCircLANDesISChanges | ||
| isisPacketCounterTable | isisPacketCountLevel | |
| isisPacketCountDirection | ||
| isisPacketCountIIHello | ||
| isisPacketCountISHello | ||
| isisPacketCountESHello | ||
| isisPacketCountLSP | ||
| isisPacketCountCSNP | ||
| isisPacketCountPSNP | ||
| isisPacketCountUnknown | ||
| isisISAdjTable | isisISAdjIndex | |
| isisISAdjState | ||
| isisISAdj3WayState | ||
| isisISAdjNeighSNPAAddress | ||
| isisISAdjNeighSysType | ||
| isisISAdjNeighSysID | ||
| isisISAdjExtendedCircID | ||
| isisISAdjUsage | ||
| isisISAdjHoldTimer | ||
| isisISAdjNeighPriority | ||
| isisISAdjLastUpTime | ||
| isisISAdjAreaAddrTable | isisISAdjAreaAddrIndex | |
| isisISAdjAreaAddress | ||
| isisISAdjIPAddrTable | isisISAdjIPAddrIndex | |
| isisISAdjIPAddressType | ||
| isisISAdjIPAddress | ||
| isisISAdjProtSuppTable | isisISAdjProtSuppProtocol | |
| isisIPRATable | isisIPRAIndex | |
| isisIPRADestType | ||
| isisIPRADest | ||
| isisIPRADestPrefixLen | ||
| isisIPRANextHopType | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisIPRANextHop | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisIPRAType | Supported as read-only. | |
| isisIPRAExistState | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisIPRAAdminState | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisIPRAMetric | Supported as read-only. | |
| isisIPRAMetricType | Supported as read-only. | |
| isisIPRAFullMetric | Supported as read-only. | |
| isisIPRASNPAAddress | Unsupported object. Always returns MIB default value if one exists for a GET. | |
| isisIPRASourceType | ||
| isisLSPSummaryTable | isisLSPLevel | |
| isisLSPId | ||
| isisLSPSeq | ||
| isisLSPZeroLife | ||
| isisLSPChecksum | ||
| isisLSPLifetimeRemain | ||
| isisLSPPDULength | ||
| isisLSPAttributes | ||
| isisLSPTLVTable | isisLSPTLVIndex | |
| isisLSPTLVSeq | ||
| isisLSPTLVChecksum | ||
| isisLSPTTLVType | ||
| isisLSPTLVLen | ||
| isisLSPTLVValue |
